RC-RAD
- Location
- San Francisco, CA
- Limitless
- Kraton 6s
- Kraton 4s
- Mojave
- Outcast 4s
I picked up a 4S slipper clutch from Jennys and I wanted to take it apart to do some maintenance (check the pads, change the bearings, clean the screw) before I put it in my rigs.
Screw backed out about halfway until it stopped. Thought I needed to apply more elbow grease but didnt budge and started stripping the screw. Thought my 2.0mm hex driver was the issue so I tried another 1....screw doesn't move...tried another hex driver...still no luck. I took a torch to the other side of slipper to burn/loosen any threadlock on the screw.....still no luck.
Any suggestions on how I can remove the screw before I take a dremel and drill it out?
Thanks in advance for suggestions.
