using the SLT3, and the prob is that i cant get the ESC to go into the mode to set itWhat radio are you using? Typically you just turn your wheels all the way to one side with the remote and either lower or raise the dual rate until the tires don't move any further.
throttle calibration is fine done it allready, im tring to do the endpoints like throttle calibration but for the servo endpoints. for sum reason i cant get it to work and i don't understand why, im sure that im doing it rightFor end point adjustment you just use the steering rate knob on the remote as I said above to adjust end points. Turn wheel all the way to say right and turn knob up until it doesn't move wheels any further. For throttle calibration you just turn ESC on holding the set button when flashes red let go of set button, with throttle in neutral press set button should flash green once, hold full throttle press set button should flash green twice, then go to full reverse press set button and get 3 green flashes and your good to go.
Thank you!! I was going full throttle instead of full brake, thats what it was now its working fine, again THANK YOU!When you go to set the end point on the SLT3, you have the wheel all the way to the right AND the throttle on full brake BEFORE you turn the SLT3 on correct?
Does the red button on the transmitter blink red until you let go of the wheel/throttle and then turn off?
Then when trying to set the end points, does hitting A/B cause the red light to blink?
Just seeing which part of the process is causing the issue
