Cap pack installation
Fenwick17
Oklahoma
  1. Limitless
  2. Senton 6s
  3. Senton 3s
  4. Typhon 3s
  5. Vendetta
Getting ready to put a cap pack on my esc. Does the distance from the esc to the pack have to be equal on both wires or as long as it's less than 3" it doesn't matter? Thanks
Double post? :)
To recap...
@K-BASH wrote:
Shorter wiring helps with ripple big time..running packs in series causes ripple much worse ..example 2 2s packs on 4s vs 1 4s pack..try to install cap closest to esc for best results like so
...and I added:
Thanks 1 pack 8s. Was wondering if wire lengths had to equal?
I honestly don't think it matters all that much...depending on your definition of "equal". If by equal you mean exact measurement to the mm or 10 thousandths of an inch...that's probably veering towards the anal retentive. But I don't think having one side be an inch and the other six is the way to go either. If they're about the same length within reason, I'm certain you'll be fine. But yeah, as @K-BASH said, try to get your pigtails as close to the base of the power terminals on the ESC as possible for best results.
