Not sure. Maybe someone else can chime in.I have a arrma kraton 6s and one of the wires from the capacitor pack broke and damage the cap pack what kind and where do I get a replacement cap pack for the arrma kraton 6s?
Ok sounds good I’ll give that a try. Thanks for the reply.Is it on the battery lead? If it is you can pick up one of the knockoff hobbywings little ones
https://www.amazon.com/Xiangtat-Low-impedance-Capacitor-Module-Standard/dp/B08BKDR4WV/ref=sr_1_4?crid=WTBQNCMEXYK8&dchild=1&keywords=rc+cap+pack+capacitor&qid=1626397931&sprefix=rc+cap+pack,aps,192&sr=8-4
This one is only like 2”-3” long and 1” tall
Thank you I will make sure I check thatJust make sure the capacitor ratings are 35V for 6S pack.
I did get it soldered back. I just wanted to have a backup if something else happened to it.I had a wire almost completely separate from the cap pack and I soldered back on, works like new. Is it unrepairable?
When you draw a lot of power from the batteries the voltage becomes a little less stable (ripple), caps in the esc are there to stabilize it. For certain applications its good to add some extra capacity. It will not directly give you extra performance.What's the purpose of the cap pack? Just got my 6s used and i doesn't have one. Max8 ESC.
