Spoc85
- Australia
- Infraction
- Limitless
- Kraton 6s
- Kraton EXB
- Outcast 6s
Does anyone know if the Caps in a Cap pack die after so many runs? The Cap pack I was using was made for 6s by a speed runner and he reckons as long as I don’t use it for anything above 23volts they should be right. After 5 runs I started noticing that there wasn’t a spark like there used to be when I would plug the batteries into the ESC. The Car also started cutting out as you will hear in the first Vid. I texted the bloke and he reckons they should be fine but I don’t know. I swapped it out anyway. The car completed a smoother pass although there was not that much of a difference in speed as you’ll see in the second Vid.
Sorry about the length of the second Vid........... the car got loose down the end there?
