Outcast Carbon chassis braces?
martin34
  1. Notorious
Hi has anyone made carbon chassis braces?I don't do crazy jumps and carbon braces would loose quite a bit of weight.
That thread speaks on the tubing to go over the existing tubes. Tmk know one makes them just out of carbon. I made a bracing system with a carbon top brace with aluminum ends. It’s in my avatar and I have a build thread. You could ask @HotdogCustoms . Perhaps they could make you a set. They are carbon fiber gurus...
If I were making a set to replace the Arrma ones I’d cut the ends off of the red ones and expoxy and pin them to the carbon tubes, doing away with 90% of the red braces. It would still be extremely strong and much lighter.
Thank you @Jimbobjr!
We actually have a set available for the Outcast 8s. They are 13mm diameter American made carbon fiber tubes with a 3mm wall thickness so they are incredibly stiff and strong but also will shave a few ounces compared to the stock aluminum.
Also available with M2C aluminum end links.
$120 for the set of four
$150 with two pairs of the M2C ends.
