Just installed and finished carbon fiber
The wing is perfect pass, I made the reciever cover with carbon fiber sheets because I could not find one anywhere...What brand?
Just an FYI (and this happens often)
These get installed blunt side facing forwards like an airplane wing. The pointed/sharp side is the trailing edge.
Sharp eagle eyes..
I flipped them around..
I mainly just run it around on my street , should I get infraction diff for it then??? Not familiar with the new rc stuff, I haven't been in it since 20+ years agoWhat is the plan for this car?
If you want to make back-to-back runs or parking lot bashing, I highly recommend getting the infraction center diff to reduce the gearing.
The Limitless spool setup is really just for single-speed runs with cool-down breaks between.
The RTR 6s ESC and motor can get you into the 90-97 mph range max if you want to try speed running.
Do I want the solid infraction center diff or stock one, if you could send a link or part number it would be appreciated...I mainly just run it around on my street , should I get infraction diff for it then??? Not familiar with the new rc stuff, I haven't been in it since 20+ years ago
