Infraction Carbon fiber receiver cover
That would be cool. I don’t have the router to cut that
A simple hand held jig saw will work .you just need to go slow and take your time .and you would need to sand it down to get a nice shape .wear a good mask . breathing CF isn't good for ya.😁👍
A belt sander would be quicker after you ruff cut it so you can smooth the edges and get round corners..
I’ve moved on I couldn’t find one I liked, now I need a flat surface one (without the Arrma logo) so I can mount my gyro on a flat surface. I’ve benched tested it plan on running the truck this weekend make sure everything’s correct before I install the gyro.
I’ve moved on I couldn’t find one I liked, now I need a flat surface one (without the Arrma logo) so I can mount my gyro on a flat surface. I’ve benched tested it plan on running the truck this weekend make sure everything’s correct before I install the gyro.View attachment 283763View attachment 283764
I think I can draft up a flat cover without the logo..
in 3D print..
Would that work for you?
Okay.
Here's some drafts..
General Dimensions
Underside Perspective
(Front Edge)
(Back Edge)
Top Perspective
(Front Edge)
I'm extracting measurements from my Infraction 6S v2 's receiver box...
Please let me know if that's the same dimensions on a Felony & the NEW Limitless V2.
Or, if it is different ,please post pics with ruler (in mm) so I can make proper size adjustments.
