I have both. 1260kv is just less RPM and might run a tad cooler, but I only have a few packs thru it so far. I don’t think it really matters as long as you have the ability to gear up for the missing KV.has anyone purchased the castle 1717 1260
is it a big difference from the 1650 kv
what would a good pinion gear size to start at if l decide to keep the same size spur gear in the infraction to hit 100+I have both. 1260kv is just less RPM and might run a tad cooler, but I only have a few packs thru it so far. I don’t think it really matters as long as you have the ability to gear up for the missing KV.
You would find it much easier to hit 100mph and beyond with a smaller spur gear or a spool. I believe someone here found a 40T spur gear to fit the stock Arrma cups. You could also do a Limitless spool and start with a 39T spur.what would a good pinion gear size to start at if l decide to keep the same size spur gear in the infraction to hit 100+
