Outcast Castle 1717-1650 Kv motor
jsimlick
New Member
Does anybody have a heat sink and fan arrangement for the castle 1717-1650 kv motor? It’s such an oddball size can…..
When you get into these size cans, you are best to get creative if you anticipate heat being an issue in the first place. As many do. A fan/fan mount blowing directly to the bare motor can will probably most effeicent. No Heat sink being used.
You never stated what rig this is going into. Very important.
Others should chime in with their fan setups and this Motor. There are many threads here on AF about this. Try searching for them.
I use a little bracket that clamps on to the can and holds 2 40mm fans. I used 24k rpm fans with mine. I did have to put a 2mm longer screw in the clamp as it was slightly loose with the included screw fully tightened down. It’s rock solid now.
https://www.powerhobby.com/phmount03.html
