- Thread starter
- #21
Huh? A heatsink conducts heat, a shroud directs airflow... they are different things.as long as the shroud is working as a heatsink it should help a lot but if the shroud itself isn’t absorbing and releasing heat it would be better with fans alone. Make the shroud aluminum, thick, with as much area touching the can as possible to suck the heat away.
Also a heatsink does not "suck" heat... it just provides a larger surface area for that heat to be transferred to the air through convection. You want a heatsink to be thin with tons of surface area so it can dump the heat into the air as fast as possible so it doesn't build up. If it is thick it will actually provide resistance to heat transfer.
