osuengineer
Hello all,
I'm new here and hoping to get some insight from anyone who has used Castle 1721 motors. To preface, this is not an RC car application, I am using these motors to spin a 50lb flywheel at 2800rpm. Currently I use 2 Castle 2028 motors at 8S geared down paired with XLX2 controllers. The problem I am having is I need this flywheel to spin up as quickly as possible, and when I gun the throttle the controllers are internally limiting the rate of the current spike causing the motors to stop running when the controllers reach this limit. If I feather the throttle it spins up no issues, it just takes longer.
So I want to switch my setup from the 2 castle 2028's on 8S to a new setup of 4 castle 1721's on 8S, geared down to spin the flywheel at the same 2800rpm. I'm confident that splitting the load over 4 motors/controllers will fix this issue. But what I am not confident in is the Castle 1721's ability to run wide open for 3 full minutes without them overheating.
These motors are claimed to be for speed runs only, which I assume don't last more than about 30 seconds. I believe it's a temperature concern more than anything, has anyone ran these motors wide open for 3+ minutes under some load?
Any experienced insight on this motor is appreciated, thanks!
