m.mahdi_sh
- Points
- 123
- Granite
Hello everyone
I needed a bec that could provide me 12 volts with 6s battery and things happened while I was purchasing and I bought
So I was wondering if there is a way to change the output voltage without using the castle USB interface, perhaps with some electronics involved?
I'm asking because I can not purchase the interface at the moment and I really need to get things running for a project that I have.
Thank you in advance, I'd appreciate any response or guidance in the matter
Castle Creations BEC 2.0
And I came to understand that it needs another module to reprogram it to 12 volt output(default is 5ish volts)So I was wondering if there is a way to change the output voltage without using the castle USB interface, perhaps with some electronics involved?
