TylerBerrys
- 4x4-Mega
Is running a 27t pinion and 91t spur going to be alright for on road, off road action temp wise?? And if so what speeds should I expect with 2s lipo 5200mah 35-50c?
Keeps saying I am going like 700mph lol I clearly am putting this in wrong...
Which Castle motor are you running?Is running a 27t pinion and 91t spur going to be alright for on road, off road action temp wise?? And if so what speeds should I expect with 2s lipo 5200mah 35-50c?
I'm assuming it's the Sidewinder 4 combo and it's going to be way over geared.Which Castle motor are you running?
This is assuming that you are still running the stock tires.Keeps saying I am going like 700mph lol I clearly am putting this in wrong...
Yes it is the sidewinder 3800kv. Looks like I might have to get a different motor housing to get a more wider range of pinions to fit with the 91 spur.I'm assuming it's the Sidewinder 4 combo and it's going to be way over geared.
Also yes running the stock DB boots tires as well.Yes it is the sidewinder 3800kv. Looks like I might have to get a different motor housing to get a more wider range of pinions to fit with the 91 spur.
I just left the 17t pinion in it with the 91 spur for temps.Yes it is the sidewinder 3800kv. Looks like I might have to get a different motor housing to get a more wider range of pinions to fit with the 91 spur.
Yup and that motor is a bit small for a 1/10 4wd it's only a 3650 sized motor. There's a reason why Arrma went with a 3660 sized motor in the 3s BLX platform.The title says it, it’s a Sidewinder SCT with the 3800kv motor (which is a 1410).
That’s one of the oldest esc’s that they still have new. It’s kinda archaic to be honest. Really a Sidewinder 2 with a fan. Honestly it’s not too bad. Just don’t overgear it, remember, it’s an old design, not really that powerful.
Exactly.Yup and that motor is a bit small for a 1/10 4wd it's only a 3650 sized motor. There's a reason why Arrma went with a 3660 sized motor in the 3s BLX platform.
That system is better suited for 2wd Short Course Trucks, 2wd Monster Trucks and 1/10 buggies.
Oh no ur fine. Didn't mean for it to sound arrogant. And yeah you're right, an MT will be pushing that system.They make a sensored 1406-3800 kv motor so I was just checking.
The 1410-3800 kv motor is going to run hot. I ran it in my Granite and it thermaled constantly. I moved it to my Senton and it did better. Still right on the edge though.
