jkflow
TB RC Bashers
Hospitality Award
Even if Lipo's are not yet capable (yet), at least the ESC is no longer the bottleneck.
Several of the testers used this set of batteries to achieve the crazy power levels. We tried to use a different battery that was rated at 6000mah 120c and destroyed the pack on our first run. We bought 2 sets of these batteries and have had no issues with these providing hundreds of amps. Honestly I think these might be the only packs that can actually push the ESC without going to a 8s2p setup.I am glad the price is similar as the XLX. Obviously in Europe it gets a crazy 30% reseller markup.
Looking at the datalogs it's maybe a little to obvious the both XLX logs have a current limit, whiles the XLX2's do not. And Raz his XLX2 log showing 547A?!?
Where can I buy those magical true 100C batteries?
Temps and ripple look very nice though. As my tortured XLX seems to have seen it's best days, i will definitely order one once they are available here.
Agreed, specifically the 6400 mAh packs are very good. The other mAh versions are not the same cell quality.Several of the testers used this set of batteries to achieve the crazy power levels. We tried to use a different battery that was rated at 6000mah 120c and destroyed the pack on our first run. We bought 2 sets of these batteries and have had no issues with these providing hundreds of amps. Honestly I think these might be the only packs that can actually push the ESC without going to a 8s2p setup.
https://www.smc-racing.com/index.php?route=product/product&path=67_190&product_id=571
This video has the runs from Example 1 from that page of comparison logs.
Even better, they made them female 8mm bullet connectorsHey @robert@castle I just noticed, did you guy extend the length of the wires also?
Another thing we asked for ?
I'm not sure what we did with the wire length. I think it might be the same as the XLX, but coming out vertical on solder posts. I think I had seen people's request for longer input wires on the MMX8S too late in the design to have an influence on the design.Even better, they made them female 8mm bullet connectors
It is actually 8 gauge wire on solder posts. Several of the beta testers unsoldered the 8 gauge wire and put 8mm bullets onto the solder posts because they were swapping the ESC in to lots of different vehicles and it made it easier for them. I've been asking for input bullets for years but apparently it is too much risk to sell any product that way. I personally would have liked to ship this ESC with 8mm bullets, or even better made a new 9mm bullet for one of the wires to keep people from plugging them in backwards. Part of the problem with putting female bullets on the input is that people will use them as the battery connector and you shouldn't have 2 male bullets soldered to a battery because it is easy for them to short out.Even better, they made them female 8mm bullet connectors
Interesting. Love to see companies interact with forums, let alone actually listen to us when designing a product. Triple thumbs up man you guys are killing it.I'm not sure what we did with the wire length. I think it might be the same as the XLX, but coming out vertical on solder posts. I think I had seen people's request for longer input wires on the MMX8S too late in the design to have an influence on the design.
8s is a sweet spot in capacitors. If we went to 10s, the internal capacitors in the ESC would have about 50% of the value. If we went to 12s, they would have about 33% of the value. If we went 14s they would have 15% of the value. So could we make a 10, 12, or 14s ESC? Yes, but it would either be massive or have lots of ripple. Above 8s voltage they fall off a cliff in capacity pretty quickly. So realistically, a 12s ESC requires a larger vehicle than is on the market currently. We looked into making this a 12S ESC, but it wasn't really feasible for us because of size constraints of the vehicles we wanted to target. It would have been 50% larger to make it handle 12s and it is already a very large ESC.@robert@castle
Just curious why was the decision made to stick with 8s and go for high amps, versus jumping up to 12s or 14s, and keeping the amps lower.
Thanks for the explanation. I am all to familiar with series and series/parallel connections from EE classes in college. ?8s is a sweet spot in capacitors. If we went to 10s, the internal capacitors in the ESC would have about 50% of the value. If we went to 12s, they would have about 33% of the value. If we went 14s they would have 15% of the value. So could we make a 10, 12, or 14s ESC? Yes, but it would either be massive or have lots of ripple. Above 8s voltage they fall off a cliff in capacity pretty quickly. So realistically, a 12s ESC requires a larger vehicle than is on the market currently. We looked into making this a 12S ESC, but it wasn't really feasible for us because of size constraints of the vehicles we wanted to target. It would have been 50% larger to make it handle 12s and it is already a very large ESC.
I can also imagine that Castle took into account that not many motors are rated for above 8S voltage. But the capacitor explanation makes a lot of sense!@robert@castle
Nice work at Team Castle.The amps are not imaginary. We have very accurate current sensing resistors in the PCB along with a high speed 14 bit ADC. I'm not going to say with the max reading is, but I highly doubt anyone will ever be able hit it. We have tested and verified that it is correct well in excess of 500 amps. Also it has a much higher resolution in the datalogs than any other product we have ever made. You should see logs with a resolution steps of 0.1 amps.
Beat me to it!
New beast ESC, I cannot wait to see pricing...
[/QUOTE$249.00
