Thank you so much. While posting your response, I noticed that the motor specs were missing.What motor are you running ?, because that RPM is crazy high and that's only at 70.6% power ?..!!
I would enable watts/hp and temp, I'm no expert on Castle and I'm sure some others will help out once they see this thread..??
Super ?. Any screenshot for those settings? I could not locate them!In the Castle software, there are settings for your motor poles and gear ratios. You need to set that up before the data is relevant.
Glad to help ?Super ? thank you so much ☺. I learned something new today very happy.
cheers
Might have been ??? I just opened the app and took screenshots.@jondilly1974 ... is that a log from your EXB ??
I was wondering about that page you mention ?
You are right. Ripple is quite high! My next plan is a homemade cap pack waiting for the capacitors only.I'm no expert here, but your ripple voltage is quite high but I do believe within the limit just ?
Are you using an external cap pack.??
I know this is a month old, but seeing your ripple and being you have the same motor/esc as me did you ever get that cap pack made? I make my own out of Panasonic FR or FM 50v 1000uf caps, and haven't pulled the trigger on cutting into my leads yet as my ripple on 8S is around 1.41v w/ 20t pinion 42t spoolFinally I achieved the 100 miles (161 kph) PB as of today. I know it is not yet wahoo! But this was my first objective.
i adjusted my mmx8s settings to get more accurate data. see my log any Comments? Please help to improve this PB.
setup: TP power 4260 2080, mmx8s, HC 4S lipo 70C 5000 mah, S/P 30/32,
In house cap pack ready, pending some adjustments before to proceed with some new testing. I will keep you updated. What about your setup and PB?I know this is a month old, but seeing your ripple and being you have the same motor/esc as me did you ever get that cap pack made? I make my own out of Panasonic FR or FM 50v 1000uf caps, and haven't pulled the trigger on cutting into my leads yet as my ripple on 8S is around 1.41v w/ 20t pinion 42t spool
I'm not a speedrunner, I'm a speedbasher ?.In house cap pack ready, pending some adjustments before to proceed with some new testing. I will keep you updated. What about your setup and PB?
