I just got a castle xlx2 and a 6s cap pack new in box for 150 is that a good deal??
I'd say so if the xlx2 is in good condition, they're ~$250I just got a castle xlx2 and a 6s cap pack new in box for 150 is that a good deal??
Then you got an absolute steal!!It's in sealed box and it comes with a Philip 6s pack , whatever that is??
The xlx2 is a monster!! If you plan on doing any kind of speed running it's pretty much the only game in town for serious #'s (120-130+)I know nitro cause that's what I grew up with but electric still new to me
You can sure run it on 6s with the stocker motor no issues. Some even tried 8s with the stocker 2050 motor. And got good results. A proper motor fan(s) will be needed for sure. Using a Fan mount, with No Heat sink is best. Consider getting the CC Log data cable to access the data logs. Start off with 6s and get comfortable speed running this way. It will be plenty fast , trust me. You will nee a good radio for faster speeds. Need radio range or you will lose control easily and that spells carnage. Speed running carnage really costs $$. There's no room for error at high speeds. We all wrecked bad. You will also. Try to minimize the risk, and be smart about it.It's in sealed box and it comes with a Philip 6s pack , whatever that is??
What does that mean if I put in limitless with stock spectrum motor
Phillip jolly pack is what it's calledYou can sure run it on 6s with the stocker motor no issues. Some even tried 8s with the stocker 2050 motor. And got good results. A proper motor fan(s) will be needed for sure. Using a Fan mount, with No Heat sink is best. Consider getting the CC Log data cable to access the data logs. Start off with 6s and get comfortable speed running this way. It will be plenty fast , trust me. You will nee a good radio for faster speeds. Need radio range or you will lose control easily and that spells carnage. Speed running carnage really costs $$. There's no room for error at high speeds. We all wrecked bad. You will also. Try to minimize the risk, and be smart about it.
Use the cap pack for sure. What brand is that? Philip? Could be a custom Cap pack. There are many boutique high quality Speed Runner Cap packs out there.
What voltage is the Cap pack rated for? 6s or 8s voltage. Can you read the caps them selves?
Usually the uF rating and volts are shown on each Capacitor.
I build my own Cap Packs now. A whole different topic.
Price looks great for that setup there.![]()
Got ya.Phillip jolly pack is what it's called
