Kraton Castle Mamba Monster 8s Ripple
Raydee
NY
Kraton 8S, Talion
Just wondering what kind of ripple you guys are seeing in the data logs with your Mamba 8s escs. I know the stock Spektrum esc came with a cap pack and wondering if I might have to add one to the Castle ESC.
gotnitro
Fartsville
Limitless, Kraton 8S
Your going to see it on the DL, never will notice any difference with a pack or without.. Some guys are going to jump in here and say they use one and that's fine. Placebo, psychosomatic.. who knows.. I have 4 RK's and use 0 because they did nothing but change numbers on paper.
phildogg
Infraction, Limitless, Kraton 6s, Typhon 6s
Depends on what your doing, batteries,gearing. ect. I use cap packs and speedrun but I'm seeing around 1.4v-1.5v on 8s around 5% ripple
so you noticed no difference in adding a rk cap pack? I find that hard to believe.
gotnitro
Fartsville
I didn't see anything other than numbers on the DL. No extra speed, no temp difference.
jondilly1974
Speed running apprentice, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
I believe my ripple has stayed under 1.6v using a Ripple Killer 8S pack. I’ve never attempted a pass without it, so I don’t have a before/after comparison.
Raydee
NY
Kraton 8S, Talion
I will have to pull my logs again but we used to use them in the boats because they can pull some serious ESC damaging amps. I am pretty sure on my last log I saw a spike of 5 volts....that is a pretty bad ripple and the last thing I want to do is burn the ESC. All the cap pack does it just supply the ESC with that first big spike of voltage when you punch the throttle. They will not make anything run faster or cooler.
gotnitro
Fartsville
Amps are pulled, volts are pushed. Pulled amps are what creates heat. That esc didn’t get any hotter or any cooler running with or without a cap pack. The ESC “damaging“ Amps would all be contributed to heat which wasn’t there.
Create account
Log in
