RC-Dude
The MM2 is 112 grams rated at ? Amps
vs.
Arrma BLX185 at 196 grams rated at 150 Amps.
How do the ESCs compare using the stock Arrma 2050 motor? Just wondering if I should replace the Arrma BLX185 in a 6s Typon running mostly 4s and 6s with a 26t pinion / 39T spur with the Castle MM2. Main reason is to keep the heat down and to acutally not have a thermal shut off before the lipo is down to 30%. Some days just bashing on 4s other doing more bashing with mild speedruns to 140km/h on 6s. Just building a Typhon 6s SWB with Limitless V1 front and rear towers, diffs shocks, center spool etc.
What are your thoughts?
Anybody some input?
vs.
Anybody some input?
