bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
I decided to run a test on the Castle MMX paired with the 1515 sensored 2200kv motor running a 16T pinion. I used 2 Turnigy Graphene 3S 4000 mAh 45C batteries. This combo is in my V3 Typhon which has an M2C chassis and shock towers along with Voltage Hobbies steer plate, chassis braces, 3 suspension mounts and the servo mount. For tires I ran Proline Badland buggy tires. I'm not good at estimating weight but I would say the truck is a little heavier than stock. If someone wants to figure it out or take an educated guess that would be great
I ran in sensored mode and data logged everything. I had LVC set to 3.5v per cell and the motor temperature cutoff set at 180 degrees. Every time you power cycle the MMX it creates a new data log session. The first session lasted 9 minutes and 54 seconds according to the data log. Based on my video footage, I show an elapsed time of 10 minutes and 12 seconds. I am not sure why there is an second disparity. In any event the max ESC temperature was 211.7 degrees and the max motor temperature was 162.8 degree. The session ended when I landed on a front wheel and pulled the pillow ball out of the suspension arm. I walked it up to my front porch and powered it down, this ending session 1. Here is the graph:
It took me roughly 8 minutes to repair the pillow ball and then I began session 2. Unfortunately the log filled up before I could finish the battery. I was able to log 4 minutes and 41 seconds before the log filled. While I was repairing the truck, the ESC had cooled to 126.5 degrees and the motor had cooled to 99.2 degrees. In the time I was able to log,the ESC hit a max of 206.1 degrees and the motor hit a max of 155.9 degrees. Here is the graph.
Once the log was full I continued to run for another 1 minutes and 22 seconds before I hit thermal cutoff on the motor (set to 180 degrees). I felt the motor and it was very hot to the touch. I let the truck sit for 10 minutes (I timed it) and then ran it for 15 seconds and it hit LVC When I looked at the last logged voltage the battery cells were at an average of 3.65v. I have LVC set to 3.5v per cell.
So there you have it. The reason I did this was to shed some light on this combo as a possible bashing option for the Arrma vehicles. I originally had it in the V3 Kraton and the motor would overheat constantly. I can't remember what pinion I was running but it was definitely smaller than 16t. Personally I would not recommend this combo for any Arrma 6S dirt bashing vehicle other than the Typhon (I have no idea how it would run in a speed rig). Even running fans in the larger trucks would be pushing it. I am going to install the same motor fan setup on that I have on my Kraton EXB and Talion. That should keep the motor temps in check. I am definitely at the top of the bashing gearing spectrum. I am theoretically geared to 70 mph.
My only real concern is the ESC temps. We had a poster a while back that claimed that the Castle ESC temp turn on for the fan is way to high and by that point irreparable damage has already been done. He claims to be super experienced but I'd really like to hear from @robert@castle concerning this. What exactly is the ESC temp that initiates the fan?
