Castle sensor wire extension! SOS!
handzace
  1. 4x4-Mega
  2. Felony
  3. Limitless
  4. Kraton 6s
  5. Kraton EXB
  6. Talion EXB
  7. Typhon 3s
  8. Typhon 6s
  9. Typhon Mega
  10. Vendetta
  11. Infraction 4x4
So I have a problem Houston! the longest sensor harness they make isn’t long enough for my application so can I just solder in the length needed from another sensor lead or ? Any suggestions my setup is limitless v1 center brace esc mount xlx2 and 1717 castle in factory spot so it doesn’t reach ! Ughhh always something to challenge you in this hobby tho ! Gotta love it!
I would call CC and ask them.
I am not sure if soldering a sensor lead is correct to do. The lead handles freqs. signals. Even a dirty sensor connection for instance can wreak havoc. Sometimes the motor's temp readings get skewed.
Call CC first.
What length have you tried or what length do you need? There are some decently long ones out there. You can connect and brand sensor cable to the cc harness
Using something like this along with the castle harness would get you another 30mm or so. Would that do the trick?
https://www.amainhobbies.com/protek-rc-braided-brushless-motor-sensor-cable-300mm-ptk-2109/p672164
Edit: just found this 400mm wire from hobby wing. You can use it along with the castle harness (pic below).
https://www.hobbywingdirect.com/products/sensor-harness-cable
Exactly what I did using the center brace ESC mount and I can confirm it works.
That's what she says.
Call CC first.
Exactly why I haven’t done it yet ..good suggestion I’ll see if anyone replies that’s been thru this before contacting cc …thanx for the tip brother
See this is why I love you guys 🥲 tears of joy lol 😂 nosa but thank you so much brother ima try this way as I was hesitant in trying to solder in a section because of the data so I was unsure …..🙏
You are the man ! Perfect! Plug n play! I apreciate you brother !!! 🙏 I’ve tried the 300mm castke harness and wasn’t long enough but with this “adapter” it mite just make it but def with the 400mm hobby wing …thanx again for the Knowledge brother
Good to know that u can use any sensor harness I couldn’t get a definitive answer on that in my rabbit holes lol but I tried the 300mm castle the longest they make and I’m short like 50mm if that so the 300 castle with that castke “adapter” mite work if not like u said there’s some long ones out there like the 400mm hobby wing someone suggested ..thank you for the reply brother !
