Thanks bud this will get me started nicely... I appreciate it!I’ve been running castle for quite awhile. I love
em.
Select a voltage manually that you want to cut off at. Don’t rely on auto lipo.
reversing
Check servo for highest voltage and select appropriately.
10% drag brake
40% brake
Very slow drag brake ramp
Start power high
100% power
75% reverse
40% punch control. I don’t recommend going below 30% to save battery wear and tear
Disable torque control unless you want to fool around with it
Arming times fine at default
Timing will depend on your motor. Castle sensored 4 poles work best with 7° timing I’ve read.
I don’t use throttle profiles for bashing. I do for crawling set ups though
I like a lot of freewheel due to my 2stroke gasoline roots. I find this set up good for airtime control
