JayP.
- Kraton 8S
- Kraton EXB
- Outcast 8s
- Outcast 6s
- Senton 3s
I just finished talking with someone from castle, the issue I opened up with my xlx2 APPARENTLY is a wide spread and known issue with XLX2 ESCs, and they're NOT working on a fix right now. Basically the ESC is trying to match the rpm of the motor, and it's FAILING which will cause the vehicle to BRAKE once getting back on the throttle with the vehicle moving. DO NOT buy an XLX2 for bashing at least, because you most likely will experience this issue. I don't know why more people aren't talking about this, because my mamba x 8th scale ESC does not have this issue... Absolutely ridiculous... 500 dollars for a combo that isn't even ready after 10 months?! I can't recall the exact date it came out, but this is just ridiculous... I don't see it being an issue for speedrunning, but when you're bashing, you're going on and off the throttle a lot... So this sudden braking will cause the vehicle to jerk violently, it's just going to cause wear on the drivetrain. If anyone wants to see a video of what I'm talking about, I'll post one.
