Just removed all 8 screws from the diff! Was nervous through the whole process but it was a success! No broken screws! My tip would be to heat up the diff with whatever method (I used a Milwaukee heat gun) and wait until the the screws come loose with medium amount of effort. If they don’t budge because you’re afraid of stripping it, then heat it up more. They will come out very nicely.
So my question is: are there supposed to be 3 plastic tabs spaced apart evenly on 1side of the diff? I’m not sure if I lost one or not.
The second question is I found a rubber disc as well that fell on the floor. The disc is about 2cm in diameter and about 2 mm thick. Is this a part of the diff assembly? I’m not sure where this came from. Thanks guys
