Marski69
- Points
- 138
- Mojave
Got 2 Mojave's 1 for my daughter 1 for me
What i've bought/got/done already:
- 2 x 3S Bashing Lipo for 6S total.
- 1 x 4S HV Lipo for use single
- 1 x Rocket-Rc 25Mm for Esc
- 1 x Rocket-Rc 30Mm for motor
- 1 x Metal Servo Arm
- 1 x 25Kg metal servo (first day driving mine broke with no real crash)
- 1 x Dustcover (U need one driving in grass and sea sand and it works)
- 1 x 4 proline dumont paddletires (i like them
Whats on its way:
- Metal steering rack with servo saver (so i can by a better servo without reggrets)
- Metal Servo bracket
- Metal steering hubs back and front
- New center diff because it disintegrated
- Front and back metal diff cases
- Bearing set
Things thats still cross my mind:
- Reinforced centre Drive Shaft
- Hard Steel Differential Outdrive cups
- Front and rear chassis brace
The center diff disintegrate today at driving on the beach.
With 4S HV it worked fine en the car is handeling al that power very good.
With 5 minutes on 6S on the beach with paddletires the centre diff just exploded.
This was no surprise I already thought this would happen
I also knew immediately what was going on.
All in all, I think I have already driven quite a bit broken on 6S, which my daughter with 4S HV does not have.
The car can run on 6S, but actually the drivetrain and other important drive parts such as bearings
are not suitable for so much power "on the longer term" and it is a postponement of execution.
4S HV against that is very suitable for the car, I have noticed.
Would you by a new car, i would first advise 4S HV out-of-the-box and first perform some upgrades to switch to 6S.
If you drive quietly on 6S, it will not matter much, but if you really want to keep the gas on,
you have a short driving time with 6S. Even though it is said that the Mojave is a tank.
It's a great car but on 6S you will soon run into limitations that need to be upgraded.
I will place a Pic of 1 of the Mojaves for the Fan config:
My intention was to use 2 fans with not too much Amp en feed them from the ESC without the need of a external battery.
Very cheap fans from aliexpress and some fan covers from https://shop.alza-racing.com/en/ is the result.
I sawed the filter on the ESC from a metal fan grill from a PC.
I can drive this without any problem in grass, sand, and other loose soil that would normally fill your entire Mojave and cause the fan to jam...
The extra fan cover on the motor is there because I was afraid my dust cover wouldn't prevent my fan from getting fresh air.
That also works
Whats on its way:
- Bearing set
That also works
