JMS RC
- Sweden
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Nero
- Outcast 6s
- Talion
- Typhon 6s
- Typhon 3s
Got a couple of different center diff mount setups in my Arrma's. Since I shimmed just about everything else, and read a bunch of good info on that right there. The play front to back in the center diff though is somewhat confusing, I understand that there has to be a little bit of play but how much ? On my outcast below i think the play is acceptable !? If I add a single 13x16x0.2mm shim in the front diff mount I have no play ! strange, by moving the spur gear front to back it feels a lot more than 0.2mm. How tight do you guys shim these ?
About the same in this setup, on this one i'm able to use a single shim and end up with the same play as the video above, the difference other than the different mounts are the bearings, video has aftermarket sealed bearings, this one uses stock.
