Senton Center diff oil to fix front tires balloon
Cool !!! That thing flies w the 16t pinion !!! I switched over to the V4 sliding motor mount as well since I was digging into it . Remember , use some heat on the screws !!!!
Thank you very much for all the suggestions and recommendations. I really appreciate it a lot
Please what position do you set the shocks pre-loads to run on pavement with 16T? Top to lowered is good? or 1/4, 1/2..
I pulled mine apart to find out that the diffs from the factory are a bit stingy on the diff oils. Especially considering how much the manual tells you to fill them.
I went 500k center, 60k rear and 30k up front to start my quest. So far I like it a lot better than stock. Front doesn't balloon up and the rear is a bit more solid, and wants to bring it around when powering through a turn (oversteer; which I like).
Overall, stock was just simply too loose and I am happy I switched everything out.
Good luck on your lube quest!
EDIT: Oops, I thought I was in the Kraton Prefix, you can ignore this if you want.
A bit stingy. I like that ?
Currently mine is set at 5/16'' rear , and 3/8'' front , but that doesn't mean you can't go lower . I was going to try a little lower the next time I drove it . Keep in mind to adjust your camber when you start making huge changes to the height .
Thank you. Can I set the nut on shock all the way top, not preload the springs, is better or bad for stability? How many degrees in the camber is good? Front and rear..
I did try mine all the way down , it did not handle very well , guess thats why I ended up at the measurements I gave you . -1 on the front and rear , you're not racing so you prob won't see a huge diff from tuning beyond that setting . It also depends on what tires you are using , maybe some fine adjustments to it when trial/error driving . Even on pavement , the truck most times is gonna slide before it traction rolls .
The 2wd SCT's we race on carpet have way more violent grip and will traction roll alot faster than when I run my Senton and Mojave even on pavement !!!!
Now it's has bandito c2 buggy wheels
I used those a while ago on my ,....... Rustler VXL , they were good and inexpensive !!! Honestly , you will see a HUGE difference if you get the sway bars for the Typhon 6s and put them on !!!!! Night and day !!!! I'll have to do a video now of mine running in the parking lot !!! LOL
Thank you very much for all the help, I really appreciate the time you have taken to share your experience and knowledge. I already installed the sway bar and yesterday I received engine mount from typhon v4. I will install it soon lol
Oh , great !!! You got the sway bars !!!! Even though this is a SCT , I chose not to make it a dirt/mud basher but rather a street handling truck , even more so now that they have discontinued it . Is this the only Arrma you currently have ?
I bougth the 6s
I bougth the 6s for me and the senton 3s for my son and before I bought a 2wd slash for bash. I want the senton 6s for street, I really love the senton in its 3s and 6s version it seems unfortunate that they have been discontinued. Senton 6s and 3s I bought them at the end of October but they were in their boxes until Christmas
