Can a limitless center spool work in a felony? Or is this a mechanical impossibility that would adversely effect driving operations.
You speed running!?Can a limitless center spool work in a felony? Or is this a mechanical impossibility that would adversely effect driving operations.
You should get a spool even if you are bashing. The 4wd kicks in and it's a lot easier to drift. And yes, a limitless spool will work but you will have to run a smaller pinion.Can a limitless center spool work in a felony? Or is this a mechanical impossibility that would adversely effect driving operations.
I see smoked out diffs and broken outdrives in your near future!!You should get a spool even if you are bashing. The 4wd kicks in and it's a lot easier to drift. And yes, a limitless spool will work but you will have to run a smaller pinion.
Put in 500k or 1mil in the center then!?Thanks, more input people, it's 1to 1 now, I like drifting too.
I guess I wouldn't know, I was gonna try the spool awhile back but read a ton on here about the pros vs consTell me about these smoked diffs Nostradamus……
I found the car would oversteer way too easy and made it hard to control at a descent speed.I guess I wouldn't know, I was gonna try the spool awhile back but read a ton on here about the pros vs cons
Why don’t you put your big boy pants on, get your hands dirty and figure it out for yourself if you want to be a smart arse.And what the pros, since your an rc whiz!!
Or you can be a douche and talk smack about something that many members have different opinions and perspectives on.. I gave my opinion and I suppose I shouldn't have.. and thats information I received from this forum, but hey spot on wize guy!!Why don’t you put your big boy pants on, get your hands dirty and figure it out for yourself if you want to be a smart arse.
Then next time you post about a locked diff you can actually say you’ve given it a go.
Don’t get all upset nowOr you can be a douche and talk smack about something that many members have different opinions and perspectives on.. I gave my opinion and I suppose I shouldn't have.. and thats information I received from this forum, but hey spot on wize guy!!
