Captain Flint
- Typhon 3s
Run it. It’s not absolutely necessaryThe plastic that covers the tip that goes into the slipper clutch gave on me and i was wondering how bad would it be to go without it?
Shipping right now is very expensive so if its not too bad could it wait or even be left out all together?
Great! but why is it there? what is it suppose to do exactly?Run it. It’s not absolutely necessary
It puts the tension on the outer lip of the driveshaft instead of the inner on the red cog insideGreat! but why is it there? what is it suppose to do exactly?
I wouldn't say it's totally unnecessary, I think it is used to cover the slots, if you get debris inside it would jam the thrust bearing which will cause your slipper to get loose.
It is also convenient to have since it holds the red male-male driveshaft piece while you remove the center driveshaft.
I bet you could wrap it with a simple tape to cover the slots.
You can rotate it so it covers it, I imagined it's like that so you can oil that bearing or something, but I can't tell I'm totally convinced...the slots are also in the plastic part.. it does not cover them.. ?
Well, so I have no idea why these slots are there...it has notches in it that lock into the slipper hub with the window slots aligned.. again the windows remain open..✌
