Ok thanks ?Isn’t your input shaft in the rear 13t I have a typhon 6s I was going to do same thing but have to up my pinion size to compensate for the 10t in the rear and change the front also. So center may not matter but if it was me I’d change everything over to same.
Thanks ?
I've never broken the spider gears in an Arrma center diff. I don't think I've even seem a post about it. How did yours break?Any suggestions for stronger centre diff spider gears ?
I haven't had it happen, but I've seen some where the larger sun gear splits. I'm guessing if you go with the mugen sun gear, you also have to get the mugen planetary gears as well.I've never broken the spider gears in an Arrma center diff. I don't think I've even seem a post about it. How did yours break?
