Typhon Changing Diff Ratio
SpeedyTyphon
  1. Typhon 3s
So I have been searching all over and have not been able to find any insight. I was trying to figure out if anyone has tried using different input gears for their front/ rear diffs? I know my 6s typhon is a 13/43 ratio, a straight cut 13T input and a 43T ring gear. If you were able to change the input to say a 17T theoretically you should be able to achieve much higher speeds due to less gear reduction.
you will not be able to accomplish this, mainly why you cant find any info because its not possible.. you cannot change one gear at a time.. the carrier is not equipped to be able to move over for the increased dia. of the pinion gear.. they must be changed in sets (ring and pinion)..?
Makes sense. Thank you
