Terrance
hey guys hope this isn't a dumb question but what do you do with the antenna wire when you change remotes? Do you have to cut and solder it yourself?
So just use the same receiver for the new remote?
The technologies between the two have to be compatible.
What do you have and what are you thinking of upgrading to?
I have the stock remote for the kraton 6s v4 and I bought a dumbo remote and receiver. Have never changed a remote on an rc so not sure the process.
Antenna wires are cut to a specific length depending on radio wave frequency. If you change it (make it longer or shorter) it can severely damage your range. Most RC's come with a small tube you should feed the antenna wire through.hey guys hope this isn't a dumb question but what do you do with the antenna wire when you change remotes? Do you have to cut and solder it yourself?
Ya im an idiot the new receiver has an antenna lol weird cause i just got a tactic I wanna put in my tmaxx and it doesn't have an antenna.
