Thanks, the reason for that design was an mistake of an colleague which an big "Spark!".
We had used uncoded plugs in the past, but it takes a lot of care to handle that. -> Mistake!
Luckily the Lipo still alive but we had to solder an new balancer cable!
Now that my girlfriend also has an Nero
, I had to find an solution to make charging "bulletproof".
Later on I will make the adapter inbuilt in a box with the connections coded like LiPo1 and 2.. or something similar.
Also I using a multiplex charger with BID and each board / box will get an chip.
It means: A girl takes a Lipo, just connecting the wires to Numbers, the charging values are already stored in the BID chip, and just pushing the start button....
What do you think, might it work?
Regards,
lonee
