vicious_oli
- Senton 3s
- Infraction 4x4
Hey everyone!
Figured I've got enough backlogged questions about batteries that I might as well throw them all in this post.
1. I have 2 NHX 8000mAh 3s batteries, and a gens-ace-r-spam Basher 8000mAh 3s, and the gens-ace-r-spam imars III charger. I always balance charge, which gets the capacity to 90%. If I want to "top off" the battery I have to change to normal charge, which will then get it to 99%.
Is that normal? Should I only balance charge to 90% and consider that a "full charge"?
2. The imars III lets me input a capacity cut-off when charging. I have it set to 8000mAh, since thats the max capacity of my current batteries, a video said that it would be safe to set it at like 8300mAh, to make sure the battery gets topped off.. but I don't want to risk it.
3. Now I just received an SMC DV Extreme Lipo, 6900mAh, 3s..
What kinda confuses me is the importance/difference between voltage and mAh capacity when charging a 3s battery. Shouldn't mAh not matter when charging, only volts? A small capacity battery, and a larger capacity battery should have the same limit in terms of volts per cell, or in total. Should I change the mAh cut off on my charger everytime I charge the SMC? Its not that I'm lazy and don't want to do it, i'm just afraid I might forget and cause some sort of fire.
Thanks!!
Thanks!!
