I have a 14.8V 7500mAh battery and a low voltage monitor that shuts off at 3.7 Volts. When charging the battery should I charge it to 80%? Which would be 6000mah?
Since you're only supposed to charge a LiPO battery to 80% and discharge it to only 20%, how many minutes (roughly) can I get out of a 7500 mah battery pack that only has about 4500 usable mah? So you only use 60% of the battery or am I misunderstanding something here.
Since the LVM shuts off at 3.7 Volts am I supposed to charge the battery to 100%?
