Vanning
All of a sudden my Kraton has been running hot...It will get way too hot within a few minutes. Normally it runs in the 130-150 range at the end of a full pack. Now it shoots way up to 170 plus fast. I've slowly been looking it over and I'm in the process of soldering some new connectors on. The reason for that is because that's about when it started running hot. (I got new Castle connectors right before the heat issues) While I'm waiting for fresh XT90 connectors to come in the mail, I decide to try and look at the motor to see if I can find anything wrong. This is a pretty neat test that could give a good indication if the motor is starting to go.
Put the motor shaft into an electric drill, and spin the motor at the drill's top speed. (secure the motor can so it does not turn) You can then measure the back EMF AC voltage from A-B, B-C, and A-C (the 3 wires) while the drill is spinning the motor. All three AC voltages should be the same if the windings are in good condition. The amplitude of the 3 voltage readings will depend on the Kv of the motor and the speed that the drill is turning the motor.
Mine checked out ok on that test but it's pretty neat that these motors are like old motorcycle generators. I also checked resistance between A-B, B-C and A-C, that was all low and the same. Checked the bearings etc also. All that seems ok.
Hopefully it's just a bad solder on one of my connectors. I'm not really a fan of the Castle Connectors...That's why I just ordered new XT90's. Going back to old faithful...they solder up way easier. I tried the big Green Castles....I don't think I'll get them again. PITA to remove if you have to.
