- Notorious
I didn't want to share this until I throughly tested it, I have a stock chassis still?, and although have RPM skid plates f/r I still had a ton of scratches accumulating due to my primary bash spot the skate park.
After testing different adhesive films (frisket, stickers), I have found the best route is something most of us have on hand, Gorilla Tape!
The problem at first was how to apply it without having to remove every screw, and tediously cutting out screw holes with this
Being an airbrush artist as my job, I have plenty of sharp blades, but this also means I know how hard it is to cut tiny perfect circles. But I had a solution for that on hand too!
This is a Fiskars swivel cutter that you can set the depth, and works best on flat surfaces. I also have traditional xacto swivel knives too, but those never work as intended for circles, and are mainly useful for cutting curves. Anyways, a good thorough cleaning of the chassis and the Gorilla Tape has lasted for 3 weeks, and still in this condition as of today. It's been through everything, even cleaning with simple green, wd40, water, sand, and blowing off with the air compressor. It's still there, and not a new scratch to be had. You can do it with an xacto, but it will be a bear. Worth it though, and something I will be applying to my m2c chassis when I get it. ??
