- Tel Aviv, Israel
- Granite
- Senton 3s
- Talion
- Typhon 6s
- Typhon 3s
- Voltage
Not screwed, i drilled a 1/2" holes and the pegs are glued into the holes.What does this look like from the side? I'm assuming screwed to a beam? How far are the peg holes from each other? up / down & left / right?
The pegs are spaced 180mm (7") up/down (in retrospect i would go a bit bigger)
165mm (6.5") left to right.
the beam is 7.5" wide
