For 1/8 Buggy i have try before many CHEAP tyres.
All was CRAP exxept One of them.
The GOOD ones and cheap i found are out of market today totally. This was 5-6 years ago. Sad i did not buy more of them before.
Good Tyres is important if you want enjoy the modern power these cars got today.
Also the cheap tyres is not straight, they shake little always.
This will destroy your engine and drivetrain like 30-50% quicker than perferct good tyres do.
So in the end the price will be almost same.
You also loose power to the ground with cheap tyres.
Your S4 car will drive like 3s because alot lost grip.
And the Car is also more diffucult handle. This can end up soon in a Huge Crash that destroys alot.
Cheap tyres is ok if you drive slow 2s trucks.
Please try avoid them max if you have fast big car.
Its not worth it at all if you have Car with alot power.
Try some good brand with Medium compound. these is mostly perfect, and last little longer.
If you do alot speedruns with 6s you want the best tyres i think. Belted stuff also.
How many Cells you drive?
How do you drive your Car?
And on what Surface mostly?
What size you got there?
40 series ? or ?.
Also what HEX ? 12 or 17mm ?
Next week i will try some new cheap 40series in a Nitro Truggy 1/8
These are 17mm Hex,
don't know how these run. I will tell more about them next week
Now i read, the car is Kraton.
S3 or S4 version?
S4 got bigger tyres than S3 Kraton i believe ?
That car maybe has 32 size ? the S4 version ?
edit:
i see you have Kraton 4s now, in your profile.
Sorry im Beginner at this Forum still
Is it 32 size then ?
Here you have Real Rubber tyres and wheels cheap. They are not glued, if you glue them good, maybe they can work?
I don't know at all
https://www.aliexpress.com/item/4Pc...expid=db211ebf-452e-4596-a73e-2a25331b4994-46
4s i don't trust these,
maybe 3s is ok
4pc wheels and tyres 30us
trippel edit
slick2500
did i link to same wheels ?
Most are out of stock. Only orange or red rims for the most part.https://www.nitrorcx.com/1motrtiandri.html
Looks like NitroRCX is putting all their 1/8 monster truck tires on clearance. Picked up a couple sets at $9.50/pair.
