Well i figured i might as well get ahead of the game seeing as i have gotten a lot of parts already.
so far i have gotten
Voltage hobbies servo mount , Front and rear chassis braces
Spektrum DX5c with 6000 receiver (should be fun to install)
T Bone racing rear bumper and TBR XV4 2.0 Front Bumper
charger Hota D6 Plus AC/DC with balance boards and charging adapters
MIP hex and standard drivers MIP 5,7 mm nut
duo bro curved scissors and reamer set
aka double play nut driver 5 and 7mm
fast eddies sealed bearing set (scared to install)
Hot Racing Aluminum Fixed Link Steering with 25t Servo Arm (couldn't find any other decent replacements?)
integy turnbuckle wrench 4,5,6mm
dynamite 5pc metric nut driver set
white lithium grease
blue loctite stick
weller 40 watt soldering station
Savox sw1210sg waterproof servo (is this the right one??)
malco ratcheting handle
probably going to get a hobby stand as well .. did i miss anything?? I am starting from scratch so i figured i would try to get everything i would need? I still need a 6s lipo (hardcase pref) and a lipo bag
once i unwrap my kraton the fun begins and i will post my building and pics as we go
forgot to add jennys rc full screw set for kraton
and eventually i will get 4s outcast backflip lp's
I am also making a work area using doubled up 3/4 plywood (1 1/2 inches should be good) i have legs from an ikea table im using (screw on with brackets)
and an irwin vice from lowes https://www.lowes.com/pd/IRWIN-4-1-...MIn93TgaTC4gIVC9bACh1CQg50EAsYASABEgKLRPD_BwE
blue loctite stick
