Cleaners for Tires & Plastics?
tobyjoe
NJ/NYC
I'm breaking down one of my Outcasts this weekend to upgrade the screws and replace some bent metal.
I figured I'd try to clean up my a-arms and a few other plastic pieces (sand any rough spots, look for cracks, remove dirt & such).
Aside from dish soap and water, what do you guys use for cleaning plastics? I don't want to use anything that might damage stuff, but I don't wanna waste precious elbow grease scrubbing. I will soak all the metal ball joints and such in 99% isopropyl to dissolve any lubricants or build-up, but am unsure if there's a good soaking agent for the plastics and tire rubber
tobyjoe
NJ/NYC
Discovered Lemon Pledge for plastics. Works very well. Still no idea if there's a good cleaner for tires that helps keep them from rotting, but Pledge is awesome and my truck smells like a clean floor.
calabiyau
Been using this for a long time on my car wheels and tires. Spray on liberally and any dirt and grease just runs off. Going to try it on my Kraton when they get a little dirtier.
Amazing Roll-Off Multi-Purpose Cleaner 32 oz. https://www.amazon.com/dp/B000FSDZTU/ref=cm_sw_r_cp_api_N9y0ybPJQ9VCY
I only buy the large bottle since it's pricey and not sure I would buy it if I didn't already have it on hand
Someone else already recommended 303 aerospace protectant for all things plastic and vinyl and it's great too
donp
  1. BigRock 4x4
  3. Nero
  4. Typhon 6s
I use straight simple green, works great and not expensive. After the final cleaning I use straight simple green with a little WD-40 mixed in lightly mist the whole truck, acts like a repellent on the next run.
firstrctruck
303 (30306) Marine UV Protectant Spray for Vinyl, Plastic, Rubber, Fiberglass, Leather & More – Dust and Dirt Repellant - Non-Toxic, Matte Finish, 32 fl. Oz
Reubydoobe
Reuby Doobe
  1. Mojave
  2. Notorious
  3. Outcast 6s
  4. Talion
  5. Typhon 6s
I found some old fishing rod cleaning fluid and that made my tires look like new.
RC Detail
  1. BigRock
  2. Fazon
  3. Granite
  4. Kraton 8S
  5. Kraton EXB
  6. Nero
  7. Outcast 8s
  8. Raider
  9. Voltage
XPS to clean.
Plexus to polish. This stuff is awesome. I bought it down the road at the cickle shop
