blakeaowen15
You want me to try to add a shim to the big gear on the left side of the diff, or add the shim to the back of the small gear?Possibly, but it is more likely improper shimming.
Try adding shims to the crown side. With time things wear and need adjusting. My Outcast just needed an extra shim after noticing a couple of clicks on the last run. I shimmed the diff probably 10 packs ago
https://www.arrmaforum.com/threads/how-to-shim-your-diff-with-pictures.7700/You want me to try to add a shim to the big gear on the left side of the diff, or add the shim to the back of the small gear?
