Arrma will more than likely replace that ESC for you. I was wondering....does that ESC have the option to reverse the motor direction ? I do not remember if it does or not. If it does, you could try swapping 2 wires between the motor and the ESC, then reverse the motor direction in the ESC. Re calibrate ESC to throttle trigger and test that out.
