- Points
- 418
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
- Voltage
Finished the beefcake exb kraton build I mentioned in another post. Mmx8s/1717 geared 20/50. I opted to shim the diffs out to be open. M2c chassis, hinge pin blocks/pins, shock towers/stand offs, center braces, and bladderless shock setup in fireteam shocks. Hot racing diff cases, center brace front mount, hubs, servo saver, and steering pillars. Rpm arms, wing arms, and rear wing brace to the skid plate, pps motor mount, jbi center brace rear mount and servo mount, reefs raw 500 servo with tall servo arm, 4th dimension Mmx8s mount, and probably more I’m forgetting now. Total time to tear down and build up was just over 13 hours and that could have been shorter without running into the snags hit with the “beefcake” m2c kit being geared at the rtr instead of the exb. Shocks are super plush and truck is a tank! As a note I would never run a truck this upgraded personally but it’s what dude wanted and paid for. I got to keep the 80% of the stock parts I took off
