What bearings are you using now?Knowing that the ESC, servo and bearings were iffy, I replaced them immediately after purchase. The only thing I ever broke was the wing mount. Even then, I didn't try to warranty it as I wouldn't expect it to survive the beating it took to break them. Get a spare set of tires and rims too. If you do much 6s running, you will destroy the stock tires before too long!!
Without a doubt, FastEddyBearings!What bearings are you using now?
Want to pick up some bearings also
Other then the mentioned above stuff, I broke a front diff ring gear. I put inner and outer shims on all the diffs and since then the diffs have been good. Best truck for the money, nothing is comparible for the price.
Sorry for long delay, yes, Fast Eddy's bearings have served me well...bear in mind that the hub bearings will still require a fair amount of cleaning if you run in sand or loose, gritty dirt. Even tho they have seals, it still seems to find its way into the races...What bearings are you using now?
One thing I've used to help maintain my bearings is cleaning them with the RPM Bearing Blaster. Really allows you to easily and effectively clean/lube most bearings.Sorry for long delay, yes, Fast Eddy's bearings have served me well...bear in mind that the hub bearings will still require a fair amount of cleaning if you run in sand or loose, gritty dirt. Even tho they have seals, it still seems to find its way into the races...
my list after ~15-20 4s runs hard bashing at pretty rough terrain:
love it anyway... i wonder every time how this thing holds up the hardest impacts
- nearly every single bearing after the 3rd run (replaced them all at once, also the bushings for steering)
- rear wing mount
- servo
- maybe the ESC; strange beavior with the broken servo plugged in (already called hobbico, need to send it in for inspection)
- slightly bend chassis
- 2 front bumpers (waiting for the tbone racing bumpers)
- diff case (the screw and cover for the sway bar)
- 3 cracked rims
- lot of cracks in the body around the rear mounts
Damn drive shaft arms keep slip off!!?Whats common breakages and issues you guys have seen with your kraton?
SlippingDamn drive shaft arms keep slip off!!?
