bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
I am trying to put together a list of spare parts to order for my Granite. There are certain parts that fall under the category of "not if they are going to break but WHEN they are going to break" and it seems that these parts are always back ordered. This is what I've come up with so far:
AR330447 - Shock Shaft EyeletSpring Perch Set - very easy to break the bottom for the front shock shaft where it meets the eyelet. If you lose the spring, that part number is AR330459 (Front Shock Spring). There is also a spring retainer clip that I lost when I busted mine shaft. You have to buy the whole shock parts kit to get it: AR330451 (Complete Shock Parts/O-Ring Set).
AR310799 - Spur Gear 91T 48DP 4x4 Mega - if you go brushless, sooner of later you will need one of these. Never in stock.
AR 310381 - Pinion Gear 14T 48DP Mega 4x4 - this is the stock 14t pinion gear. The 17t pinion gear is AR310383.
AR320401 - F/R Lower Skidplate (2) 4x4 Granite Mega - You will end up with plenty of spares for the rear because they make you buy both but the front is the one that breaks the most.
AR708001 - Flange Lock Nut M4 - wheel nuts tend to come lose. Axial AX31250 fit and come in a 10-pack. Traxxas 3647 also fit and come in an 8-pack.Either may be easier to source or priced better than the actual arrma ones (Credit to BattleShrink).
AR310784 - Wheel Axle (2) - tighten a wheel nit too tight and you will need one of these. Also used in the differential input gear mod.
AR310802 - Diff case, 49T Main Gear and 17T Input Gear (1 Set). - For when you snap the rear diff input gear. Again, they make you but a complete set so expect lots of extra parts.
AR310789 - Slipper Hub. It's possible to break the slipper hub if you tighten the slipper nut too tightly. https://www.arrma-rc.com/part/AR310789
AR310864 and AR310780 - Front and Rear Composite Slider Driveshaft Sets: https://www.arrma-rc.com/part/AR310864 and https://www.arrma-rc.com/part/AR310780
That's my list so far. Please let me know what else to add to it. Thanks!
