Gears, bearings and Shock parts are good to load up on for a new Kraton owner. For starters.
Id advice them that also
Change my oil shocks to this i think its 70weight from losi
And servo id change too n servo saver
And bulkheads.Gears, bearings and Shock parts are good to load up on for a new Kraton owner. For starters.
Or...shim gears, get a Fast Eddie bearing kit and don't allow too much down travel in the shocks. That will get you lasting longer than Ready to Run gives you.
Maybe V3 will be better !
Check your local hardware store for screws if you are in a bind and don't want to wait, most of the screws at Menards are like 20 cents a pop. Although some of the longer screws can be hard to find. Iirc I ended up buying some stainless steel Phillips screws for my shock mounts while I waited for the hex screws. I am not sure which screws you ordered I went with the Team Associated ones and they seemed to hold up better than the Arrma ones.beat the poop out of my kraton today. only thing that happened was i bent the screw that holds the shock to the shock mount.. 2.99 and a couple days of waiting and ill be good as new.. This thing took an absolute beating today. tough as nails.
I bought a complete Kraton screw set with all the tools for $10 shipped from fleabay. I have a jar full of extra screws. If I loose or bend one I just install another. If I mod something and need a longer screw, got one. Just buy a set, great thing to have in a rc toolbox.beat the poop out of my kraton today. only thing that happened was i bent the screw that holds the shock to the shock mount.. 2.99 and a couple days of waiting and ill be good as new.. This thing took an absolute beating today. tough as nails.
Absolutely love the Tekno truggy skocks on my kraton!The bags marked "Tekno" There is the answer. Shocks are awesome.
I bought my self a vice too lolSometimes you just need a big hammer and a vice.
1st thing I broke was the chassis and it was back ordered for ever. I have broke three slipper clutches a bulk head and two drive shafts from battery wires getting tired up in the drive shaft. also one axle shaft front bumper and rear wing.I upgraded and put a chassis brace on it but the new chassis still has some cracks.I end up working on it more than enjoying it. I have the v2 as some have said buy two for spare parts.So far , iv been pretty fortunate with my Kraton. But it is always nice to have spare parts on hand.
What are some things that you guys find you break the most on your Kraton?
