Operator7G
For those of you rock racers out there, here's how the Senton compares to Axial's Yeti. Both are 1/10, but the Yeti's wheelbase is quite a bit longer. The Senton's 2.2"/3.0" SCT wheels are basically the same as the Yeti's 2.2" deadlocks, but the Yeti's higher profile tires are a lot bigger in diameter. I didn't weigh them, but it feels like the Senton is slightly heavier than the Yeti, probably most likely due to its 3mm aluminum chassis.
With bodies on:
Inside chassis view:
With bodies on:
