Typhon Compatible Typhon Body
SteamRollingGranite
Allentown, Pa
I'm looking to get information on what aftermarket bodies will be a near direct fit to the stock body mounts for the Typhon. If a little body trimming is needed, that's fine.
Skaxis
Since the Typhon is a close relative to the Team Durango DEX8 you might be able to fit one of it's body shells on. Do note that the DEX8 has a single rear body post and the Typhon has a dual rear body post so you might have to use the DEX8 rear body post hardware. Theoretically that should be:
jbarelds
Won't work. I know cause I tried. The Typhon doesn't have a mounting spot for the rear post on its chassis brace, and the DEX8 brace is a tad bit shorter (about 2mm).
Bladerunner
  2. Raider
Hey guys , I'm lookin for a body to fit on my team Durango DEX8 conversion to a DEX8, I was thinking about the DEX8T truggy body and if it would work then great ,or my other option is the Typhon body .
or if any other 1/8 buggy would work?
