7k 15k 7k is what I’m running at the moment, do you think I should go lighter?After your own fingers weight is your biggest enemy, those race spec truggies are lighter. Shocks are better, have more positions and more options to adjust camber & toe etc.
But to answer your question i'd go for 4s, light oils in the diffs (you want diff action on a track), good track tires depending on surface, and as Jerry said practice, practice, practice
5k-7k-3k is a common used track setup for 1/8 buggies.7k 15k 7k is what I’m running at the moment, do you think I should go lighter?
Wow that’s in-depth only half way through and my brain is hurting5k-7k-3k is a common used track setup for 1/8 buggies.
Get yourself a beer and read through this:
http://stories.jqracing.com/the-guide/
It's very detailed and informative.
Lol, that's why i mentioned the beerWow that’s in-depth only half way through and my brain is hurting
